Display the Peer Information
Use the following procedure to display the peer configuration and SA message information.
Switch:#enable Switch:1#show ip msdp peer 2.2.2.2 ============================================================================ MSDP Peer - GlobalRouter ============================================================================ MSDP Peer 2.2.2.2, AS 109Admin Status: Enabled Operational Status: Enabled Description: Connection status: FSM State: Established, Establish Count: 9, Connection source: 2.2.2.17 Uptime (Downtime): 1d10h, Messages sent/received: 436765/429062 Connection and counters cleared 1w2d ago SA Filtering: Input (S,G) route-policy: none Output (S,G) route-policy: none SA In count: SA out Count: SA-Requests: Input filter: none Sending SA-Requests to peer: disabled SA Request In Count: SA Request out Count: SA Response In Count: SA Response out Count: Peer ttl threshold: 0 SAs learned from this peer: 32, SAs limit: 500 Peer RPF failure Count: KeepAlive In Count: KeepAlive out count: Encapsulated Data packets In: Encapsulated Data Packets out: KeepAlive Timer: Peer Hold timer: Connection Retry timer: Encapsulation type: MD5 Authentication: Enabled, MD5 Password: %d462277d77 Peer FSM Established Time: Peer In Message Time: Remote port: Local port: Number of connection Attempts: Discontinuity timeout: Too Short MSDP message Rx count: Bad MSDP message Rx count:
Variable definitions
The following table defines parameters for the show ip msdp peer command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
vrf WORD<0–16> |
Displays configuration info for a particular VRF. |
vrfids WORD<0–512> |
Displays configuration info for a particular VRF ID. |
